Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-19-2010, 10:58 PM
Cobra Make, Engine: Johnex EQ
Default Cam Sync
I have a 460 Ford with a danny Bee belt drive. Want to put a Cam Sync gear on. Has any one done this? If so please tell me what parts I need. I called MSD for a dual sync Dist., that was a no go
Why you say? I have stack fuel injection setup. To install, no electronics yet. Thinking of Fast or Bigstuff THANKS ED
Ed
Johnex EQ 514
Old 04-20-2010, 04:32 AM
F.A.S.T. sells an FE dua synch distributor for the FE - doubtless have them for the 460 too. I've had problems with them though.
Best easy bet is to break all but one tooth off of the stator inside the MSD distributor. Instant cam sensor.
Then use a crank trigger for the crank signal. A small block Chevy trigger wheel is about right - you'll need to fabricate the mount.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 04-22-2010, 12:15 AM
Default Belt Drive Cam Sync
MSD has a cam sync pick pickup kit #2343. I was thinking about glueing the mag on the cam gear and fab a bracket for the pickup. What your input ?
Ed
Johnex EQ 514
