Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-21-2010, 12:01 PM
Dennis O'Shea's Avatar
Cobra Make, Engine: 08 Mustang GT
Unhappy Need some help
Can anyone tell me where I can locate specfic info on a 7.5/460 "super cobra jet-550HP Ford Racing Perfromance Crate Engine.I would like to find paper work on the engine have tried ever where with no luck.what I am looking for is info such such as plug gap etc on the engine
Help
Old 05-21-2010, 12:30 PM
lovehamr's Avatar
Stolen Avitar
This it? What ignition are you using?
http://www.jegs.com/i/Ford+Racing/39...521FT/10002/-1
Old 05-26-2010, 09:18 PM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
The best thing to do is the get the Ford Racing engine number from the engine tag on pass side of block and call Ford Racing Techline, they have the spec sheets on the engines. They changed specs/parts each year on those 460's when they were being produced so you want to get the correct specs.
"...some assembly required, ages 8 and up...... well that took longer than expected......
Old 05-27-2010, 04:24 AM
Default Not trying to be a smart@$$ but
Dennis O'shea Dennis This is something that is not etched in stone. You need to read the plugs and see what the motor likes. If you are running a high voltage ignition system, the gap could be .080". If you are running points, .032". If you are running an MSD system I would start in the .044" range and drive the car for 100 miles, pull the plugs and see the color. You are going to look at the heat range too on the center electriod. As far as plugs, run ONLY Autolites in the motor. If the heads are Aluminum use a LITTLE antiseize to install and remove the plugs. Don't pull the plugs when the motor is hot. Can kill the threads in the head. Some heads have helicoils others don't. Some where between .044"-.060" will be a good place to start. Rick L. Ps they only give you a starting gap. They expect you to either read plugs or take the car to a dyno for a setup.
