Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree9Likes
  • 2 Post By
  • 5 Post By
  • 1 Post By
  • 1 Post By
Old 07-27-2016, 06:39 AM
Cobra Make, Engine: Everett-Morrison, 434 cid
Horsepower/torque is one of the biggest factors there.
Most of your Mountain Motor and some of your Pro Stock engines use extremely long strokes.....like 5.5-5.75". They will zing to 8000-9000 as quick as you can get on the loud pedal.
Long stroke Pro Stock engines? I don't think anyone uses a bore smaller than 4.70" with stroke in the 3.50"-3.60" range. I think they are also using an 8.90" deck height to keep the compression height to a minimum while utilizing a shorter, lighter rod and to keep the push rods shorter. Regarding rods, I believe they are running Honda rods. They're basically BB's built to ultra-light SB specs except for the bore... so they'll rev...
Old 07-27-2016, 07:16 AM
Depends on the class...
EXTREME PRO STOCK 932 CU. IN. 2140 HP RACING ENGINE - Sonny's Racing Engines - Sonny's Racing Engines
Google some of Pat Musi's stuff and take a look at some of the mountain motor classes.
Obviously the parts are light but I'm using this as an example when people say a big block won't rev....or a long stroke won't pull rpms...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-27-2016, 08:08 AM
Got it... when you said "Pro Stock" I assumed you were referring to NHRA Pro Stock a.k.a. Pro Stock...
I understand your references and your point... I agree. A more accurate generality would be that lighter revs higher and accelerates quicker (engine accel) than heavier, all else being equal. Of course, when comparing SB to BB nothing else is equal... but they sure do go to extremes with the Pro Stock stuff to copy a small block rotating assembly, huh?
Old 07-27-2016, 10:05 AM
Lighter parts are certainly easier on the system. I can't imagine the piston speed of a 5.750" stroke setup at 8000 rpm.
You'd be surprised at how quick a 12.5:1, 720 hp Ford FE will rev though with a 4.250" crank....that's not really anything exotic, and the crank weighs about 70 lbs.
Old 07-27-2016, 12:55 PM
Tom Wells's Avatar
https://youtu.be/pYIkzqBjdHo
