Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree1Likes
  • 1 Post By sllib
Old 04-16-2017, 06:13 AM
Cobra Make, Engine: cobra
Default engine problem
Hi
my engine 351 ford windsor stroke 393 does not rise more than laps after the 5000 revolutions / minute. It can be a problem of carburetor or ignition?
Old 04-16-2017, 06:28 AM
Tommy's Avatar
Language is a challenge so I will be simple. No easy answer to your question. Has this always been a problem or did it just begin recently? What ignition and carburetor on your engine?
Tommy
Previously owned EM Cobra
Old 04-16-2017, 04:15 PM
pgermond's Avatar
Originally Posted by norbert79 View Post
Hi
Could also be weak valve springs.
Phil
http://www.uniquecobra.com/
Old 04-17-2017, 10:08 AM
cycleguy55's Avatar
Should this thread not be in the Small Block Talk forum? Small Block Talk - Club Cobra
Brian
Old 04-17-2017, 03:18 PM
Registered User
Cobra Make, Engine: Superformance MKIII #127 Guardsman blue, 351w stroked to 393.
I had a similar problem and it turned out to be the valve springs.
Old 04-19-2017, 07:55 PM
Gaz64's Avatar
Any 4 stroke running out of puff at high rpm can have one the above, either carburettor or fuel supply, weak ignition - spark misfire, valve float from weak springs, restricted air filter or mufflers etc.
Old 04-20-2017, 01:18 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
This may sound like a stupid question, but are you using a MSD buzz box with a 5K chip installed?
Pete Munroe likes this.
Old 04-21-2017, 05:55 PM
Dwight's Avatar
Smile
I worked a Cobra with a 351W that would not rev above 4300 rpms in any gear. Stopped on the side of the road and removed the air filter then it would rev to 6,000 rpms with no problem.
I think Sllib has it figured out. MSD
Dwight
