Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree6Likes
Old 05-04-2018, 04:00 PM
Cobra Make, Engine: Everett-Morrison #1320, 514 BBF, Richmond, 3.73 , IRS
Send a message via AIM to Trubble Send a message via MSN to Trubble Send a message via Yahoo to Trubble
Default Long winter, now she won't start!
My 514 BBF with Holley 4150 DP sat thru our long Ohio winter - over 120 days. Now, she cranks over ok, but no hint of engine starting. She ran fine late last fall, but now, nothing.
I have searched the net and this site and read that possibly I need to fill the float bowls, but I can't tell you how many years it's been since I touched a carb. I Don't want to cobble things up, and would appreciate any advice.
I'm very willing to learn about the care of this beast.
Thanks in advance for any assistance.
Old 05-04-2018, 04:50 PM
On the bowl that is towards the front of the car, unscrew the brass sight plug on the side of the bowl and remove it and the little washer that is on it. Then fill the bowl, via the vent tube that is on the top of the carburetor just behind the bowl itself -- it looks like a little open pipe. Use a squirt bottle and fill the bowl up through that vent tube until gas spills out the sight plug hole. Then put the sight plug back in, pump the throttle three or four times, crank it, and repeat. It will usually fire up on the second or third go.
Pete Munroe and 40k Later like this.
Old 05-04-2018, 07:38 PM
Patrickt,
Thanks for your reply. Your explanation is clear. I'll be out in the garage tomorrow working on getting her running again.
Bill
Old 05-04-2018, 08:00 PM
twobjshelbys's Avatar
Have you verified spark? If you have a MSD especially. My Cobra ate two of them.
CSX4005LA
Old 05-04-2018, 08:56 PM
Also try tapping where the fuel goes into the bowl as the needle and seat can sometimes jam shut. JD
Old 05-04-2018, 09:04 PM
No. Have not checked spark yet.
I suspected fuel first. After lots of tries yesterday, did not get any hint of fuel smell at carb. If she still won't go, then will look at spark. What was your issue? Fried ignition box? Do you know why your car ate 2?
Thanks for checking in.
Bill
Old 05-04-2018, 09:05 PM
Jaydee,
Thank you- will give that a try too.
Old 05-04-2018, 10:42 PM
EM-0785's Avatar
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Hi Bill,
Maybe for lower on the list, but clogged fuel filter? Good luck...Brent
Old 05-05-2018, 03:46 AM
Gaz64's Avatar
120 days of winter, how much fuel was in the tank at last shutdown?
Old fuel, high water % from condensation?
Old 05-05-2018, 06:16 AM
Ron61's Avatar
I hope that you have found your problem by now and the car is running. But just a thought for future long storage times. I use Staybil in my gas for the cars and my lawn equipment and have never had a problem with the gas going bad.
Pete Munroe and Trubble like this.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 05-05-2018, 06:37 AM
EM-0785's Avatar
Bill,
Perhaps badly fouled plugs, needing cleaning or replacement, with spark coming through then getting impacted?
Brent
Old 05-05-2018, 06:42 AM
FWB's Avatar
FWB FWB is offline
Ron, it's not fair to everyone else, when you have the help of 2000 shasta pygmy's that sneak into your garage at night
Fred B
Old 05-05-2018, 12:15 PM
Ron61's Avatar
Yea Fred, but those blasted things track dust everywhere.
Ron 61
Ronnie Widener
Old 05-05-2018, 05:11 PM
Ron/Gary and everyone:
Gas tank was filled over winter, and had fuel stabilizer added.
Patrickt, using your priming technique, I did get her to fire briefly, but only had time to do the prime process once. Will be back at it tomorrow, since you suggested I repeat the process.
I am planning to pull plugs and replace if necessary. Same for the fuel filter - don't know how old it is, altho it looks clean.
I really appreciate all the advice.
Bill
Old 05-05-2018, 06:13 PM
Once you have filled the bowl up, you should not have to fill it again. Rather, pushing your accelerator pedal to the floor three or four times will allow the accelerator pump to squirt some gas down in the carb. Tomorrow, just get in the car and pump the accelerator to the floor three or four times slowly, wait a few seconds, then crank it while pressing on the accelerator pedal about an inch or so.
Old 05-05-2018, 06:27 PM
Patrickt:
Got it! Will do precisely that!
Brent, I think plugs are OK, as it ran fine last December, but I still intend to pull and inspect them.
Bill
Old 05-06-2018, 04:14 AM
Cobra Make, Engine: Superformance #678
Sounds like the fuel pump may be having an issue getting gas to the carb?
Old 05-06-2018, 04:22 PM
Sir,
Your detailed advice worked like a charm! This newbie got her started easily after several slow pumps of the throttle.
Wondering if I ought to just start a"BUILD LOG" covering this and some other issues I have to sort out....
Later.
Bill
Old 05-06-2018, 06:52 PM
Sir,
Later.
Bill
Yep, most things on these cars are actually pretty simple. Some of them are incredibly simple (like an empty float bowl). But, if nobody takes the time to explain them to you, then you have to figure them out on your own, which usually means breaking stuff, or making the problem worse the first couple of times, and then you figure it out.
Old 05-07-2018, 03:40 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Full tank of non ethanol fuel with Stabill and a blast of starting fluid has worked for me for 10 years ....
