Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
February 2026
Old 07-21-2002, 08:48 PM
Cobra Make, Engine: A&C 460
Question 460-Toploader
Picked up a 28 spline toploader from an FE Mustang. Want to put it behind my 460. I can't remember if there is something that conflicks on the input side or not. Can anybody shed some light on this combination? Also want to use hydraulic clutch. Who makes the right scattersheild?
Old 07-29-2002, 10:58 AM
Thumbs up 460-Toploader
Hi Gman,
Looks like you are planning to run the same combination as me.
I currently run a 460 BBF mated to a toploader using a 400 ford bellhousing. Had to have a 2mm spacer plate laser cut between the bellhousing and motor. Also don't forget to put a bearing on the end of the input shaft of the toploader, should fit snug inside the end of the 460 crank. Besides that run 11 inch centre force clutch or similar and a matched steel flywheel.
I am currently using a hydralic slave cylinder conected to the clutch fork, to do the changing as my car is right hand drive. If I did it again I would change to hydraulic release bearing.
Hope this helps.
All the best
Old 07-29-2002, 04:43 PM
460 Jules,
Thanks for the input. I thought the hang up was the input shaft length but I couldn't remember for sure. Thanks again.
Gman
Old 10-15-2002, 12:24 PM
Hi, 460 jules Dave here from dorset building a dax with a 429/topldr combi, just having the chassis redone, the eng mtgs were wrong, I am just looking at rebuilding my rug av with a 31 spline shaft, how is the 28 ok?also trying to source some tight headers without spending silly money, anyone any ideas, always willing to talk cobras. Dave Keane
Old 10-15-2002, 01:18 PM
Cobra Make, Engine: ERA 427 SO
460 Jules, you might get by with the 28-spline, but if you ever hook up your rear tires, you're gonna twist that puppies nose or tail...lotsa torque on your 429/460, but not much weight to push around. Good luck
Ken
Old 10-15-2002, 03:28 PM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
It is POSSIBLE that McLeod has their new bellhousing for Ford BBs ready to go.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
