Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 09-02-2002, 08:31 PM
cdog's Avatar
Cobra Make, Engine: Titanium SPF, 521 CID Gessford.
Default 460 Stroker with broken cam
My 460 Stroker (533 cid) was running good.
Backed it into driveway, tried to start it, wouldn't fire. Distributor was turning, rockers not moving... (uh oh)
Pulled motor, found cam in 3 pieces. This is a hyd. cam not real rumpy, 1.8 roller rockers, not a real built motor, about 600 HP.
Any ideas what would cause a cam to completely break?
Thanks
C
Old 09-03-2002, 08:44 AM
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
cdod - catastrophic engine failure can be caused by an almost infinate number of things. We will need more details, but usially on the teardown of a engine the cause of a failure becomes self evidant. I don't think you will get many replys unless you include more detail of the failure. As a side issue, a cam failure on the shutdown of a engine such as this usially means most of the engine parts have been spared a high rpm self destruction. Your rebuild may be a simple one if you are lucky. LOL
cobrashock
Ron Shockley
Old 09-03-2002, 08:59 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
What kind of cam? We had 3 Crane Cams break due to poor hardening....very frustrating.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 09-04-2002, 03:11 PM
cdog's Avatar
The cam gear pin sheared... cam broke, took out 6 intake valves..
I will be rebuilding with a new solid roller cam. I am thinking of going to a comp cams magnum 292 grind or something similar. Anyone have any experience with this cam?
Join the N.R.A. -- Homeland Security begins in YOUR home.
