Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 11-03-2002, 08:14 AM
limebluie's Avatar
Default 460 lifter bore angle dimension
Gentlemen,
I am currently having a problem keeping cams in my 460. This is a newly rebuilt motor that is going through a proper break in but is still wiping out cams (hydraulic). I need to check the angle of the lifter bore and there locations before I move forward. I need help finding this data.
Thanks Tom
Old 11-03-2002, 08:26 AM
Tom Wells's Avatar
Hi limebluie,
What fails? Are the cam lobes being eaten? Does the cam push the water pump into the radiator
Are these flat lifters or roller? New lifters or used?
A little more description would help.
Tom
Old 11-03-2002, 08:40 AM
limebluie's Avatar
Tom Wells
This was a Comp Cam 280 Hydraulic flat tappet cam. No it did not Push from its installed location. The cam lobes and bottom of lifter look like they were put on a grinder.
Old 11-03-2002, 09:01 AM
Tom Wells's Avatar
Hi limebluie,
Here's a place to start.
Crane Cams failure tech page
Note the "Click for closeup" places - see if one of them matches the appearance of your dead cam & lifters.
Sorry it isn't more specific. Let us know if it helps any
Tom
PS: I've had cam failure too so I know what's involved - mine was a defective Ford crate motor distributor that ate the gear off the cam...
PPS: Also, as to the lifter bore angle, the site says "or the angle of the lifter bore is not 90 degrees to the centerline of the cam" - the inference is that 90 degrees is the correct angle.
Old 11-06-2002, 08:47 AM
Have you used or installed a cam thrust plate? The problem you described may be a cam "walking" problem. I believe this is also ties to (at least in part) to the cam/distrib. wear problem. The best one I have found is at :
www.bluethunderauto.com
I have never had a lifter related problem where I have had to check the bore angles. Performace engines with racing cams, esp. rebuilds that have lots of miles, need this backup plate for the cam.
Tom - Good site at Crane Cams.
cobrashock
Ron Shockley
