Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 05-04-2003, 04:46 PM
BlueRooster's Avatar
Cobra Make, Engine: SPF #623 460/4x2
Default 460...tube coming out of...
The Bellhousing hole on the drivers side. It is full of oil/engine. Is this for bleeding the clutch? it hangs down to the frame rail, and it looks like it has some sort of fitting on the end of it
Dane
Old 05-20-2003, 08:02 AM
XXQQQME's Avatar
Cobra Make, Engine: West Coast, Ford 460
If you have a hydraulic throw-out bearing then it should be the bleeder line for the clutch. Actually there should be 2 lines coming out of the bellhousing. . . 1 from the slave cylinder and the one you're talking about. This clutch should be bled just like brakes.
'bacher
