Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 07-20-2004, 01:28 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default 460ci . . . Where do they go?
Before laughing, just remember this thing was stripped when I got her . . .
Where is the correct placement for the coolant temp sensor and the oil temp sensor on the engine?
Just want to be sure here . . . .
I'm not busy because I did it right the third time . . .I think!
Old 07-20-2004, 02:49 PM
Stick the oil temp sensor in the coolant and the coolant temp sensor in the oil. DUH!
Water temp boss should be in intake manifold.
Oil temp boss can be built into oil pan or you can put it in a remote oil filter adapter if you are not running an oil cooler. Some of 'em even have 5 holes I think so you CAN run it and an oil cooler.
Hope this helps.....
J.P.
Ohio Cobra Club
Token Gashole
