Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-08-2004, 06:26 PM
Cobra Make, Engine: Superformance Ford 460 SVO 585 HP 545 TQ
Question Desk Top Dyno Questions
I recently purchased a Superformance Cobra with a Ford 460 SVO motor with a competitiion cam ( magnum roller cam .663 lift/300 Duration), roller rockers. The motor # is M-6007-B460. It also has roller valve springs, MSD distributor and MSD 6 AL ignition. It also has a 850 Holley double pumper. The owner ( owned his own Ford dealership) claims the car puts out 700+ HP. Is this accurate or exaggerated? The car runs on race fuel and has a 12:1 compression ratio. Please let me know. Thanks Bmarze.
Old 10-09-2004, 12:26 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
M-6007-B460 is Ford's 535 horse crate motor. Plugging those specs into the program I get 545 torque and 517 horse versus Ford's advertised 530 torque and 517 horse. Changing the cam specs to yours and the compression ratio I get 594 torque and 589 horse. I think 700 is a little optimistic.
Jack
XSSIVE .....
Old 10-09-2004, 09:21 AM
Hotfngrs,
Thank you for the valuable input. BMarze.
Old 10-09-2004, 10:51 AM
Hotfngrs,
Old 10-20-2004, 03:34 PM
Cobra Make, Engine: B&BEFI 302 w/ AFR Heads 3.73 Rear, Coil-Overs
Hotfingrs,
What Head Port Design and Exhaust options have you chosen in the program? I am getting slightly higher. This is a great excersize, as I have been wanting to go the 460/514 route and need some justification (albeit, not too much from a 306).
Thanks,
Darren
Old 10-20-2004, 03:49 PM
Hotfingrs's Avatar
Large tube headers with mufflers...not sure which head I used. While the CJ heads are good, more can be gained with aftermarket.
Jack
XSSIVE .....
Old 10-27-2004, 09:51 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Check out my projected engine stats via chart which my guys say they are going to beat with the 460 and tric flow heads.
Fitz
fitzus1@gmail.com
