Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 05-18-2006, 08:48 AM
Greg Curtis's Avatar
Cobra Make, Engine: spf1266 460,TKO,titanium/black stripes
Smile Spark Plugs and Timing
I have a 460 crate from ford 485hp and was wondering what spark plugs you guys use for the best performance. Also what are you setting your total timing at. I'm at 18 mechanical and 16 initial and the car is no slouch but I feel I could be getting more out of it especially on the bottom end.
Thanks
Greg
Greg
SPF 1266 460/TKO
1971 Chevelle SS
1967 Pontiac GTO Ram Air
1962 Thunderbird Conv.
1991 Mustang GT Built
Old 05-18-2006, 01:23 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Tuning
Thanks
Greg
Carbureted? Mechanical advance only or mechanical+vacuum? What kind of distributor are you running? Are you sure the bottom-end isn't a fueling issue?
16+18 = 34; which is about right for total advance.
16 base advance is also about right.
However, how you get from 16 to 34 and when can make a big difference in the mid-band performance. Getting that curve right isn't easy...lots of trial and error unless you have a shop that has a distributor machine and can do this on a bench.
If you havn't seen this distributor yet...take a look. http://www.cranecams.com/index.php?s...&lvl=4&prt=127
It eliminates all that mechanical/vacuum stuff and makes things a whole lot more repeatable and predictable.
Old 05-18-2006, 02:28 PM
Default Spark Plugs and timing
Byron
750 Holley with vacuum secondary which I understood was better for the street. MSD distributor and 6AL ignition box. Fuel pump I'm not sure it came with the engine I guess!
Greg
SPF 1266 460/TKO
1971 Chevelle SS
Rate This Thread:
