Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 09-26-2006, 09:32 AM
Thumbs up brake vaccumn
Hi Guys, anyone running a victor on their 460? I have both a perf rpm/victor and am just trying to figure out the issues with the vaccumn for the brake servo, anyone give me any feedback. Thanks Dave
Old 09-29-2006, 12:43 PM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
Don't run a "T" for PCV valve and the brake servo. Run them separate, the brake direct to the manifold, and the PCV line to the base of the carb. Works great.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 09-29-2006, 02:04 PM
wizard's Avatar
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
Likewise on the PCV to Carb. Brake to Manifold. Although I have an Automatic (C6) and my vacuum line to it and the brakes are T'd. No problems
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
Old 09-29-2006, 02:12 PM
Zoom This's Avatar
I have a Victor Jr. intake on my 418W stroker. The original engine builder put a "T" so that both the brakes and pvc valve both used the vacuum source off the base of the carb. I upgraded this patch work by drilling and tapping a hole in the intake manifold at one of the rear mounting bosses reserved for either a coil mount or carb return springs or.....whatever.
Looks better and is now in spec.
Bill
Old 10-04-2006, 10:11 AM
Thumbs up re vaccumn
Thanks Guys, I take it that it is normal to have to drill and tap for an attacment point for the servo line? Dave
Old 10-04-2006, 12:04 PM
wizard's Avatar
I have a Performer 460 Manifold with 2 ports. (I can't tell you if they were factory or if the builder added them. I also have 2 points in the water jacket, 1 for temp, the other had a plug which I removed to add a pressure guage. All seem to be factory.) Front is used for vaccum guage and rear has a T for trans and brakes. PCV is connected to the Carb.
