Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
December 2025
Old 10-09-2006, 03:16 AM
Question Keith Black Pistons & Ford Racing Camshaft
Hello, I have just ordered the Keith Black 401 dome Pistons ( 060. 11-1 compression with the 97cc heads ) along with the Ford Racing camshaft M-6250-C460, Hydralic cam with 588/614 lift for my 460ci engine, what I would like to know is will the stock Ford head and cap bolts handle the high compression of 11-1 ? what head gaskets to use copper or stock , My 460ci is a D9TE block can I use this camshaft. with my cast heads which have new 2.25 inlet valves and 1.76 exhaust , both inlet & exhaust ports have been opened up to Cobra Jet specs. I am thinking of having the Crankshaft & Conrods balanced as my 460ci is Externally balanced, Which is best for Performance- Internal or External Balance, as not to many people know much about 460ci engines down here in Australia.... Thanks Jamie. AUSTRALIA.
Old 10-17-2006, 05:07 PM
At 11:1, you won't have any problems with a quality stock style head gasket and stock head bolts. Stay away from copper head gaskets in anything but a dedicated racing engine, and even then they're a pain.
The block will need no mods for that cam, but you will of course need aftermarket valve springs and rockers.
On the balance issue, under 6000rpm it doesn't really make a difference. If your rpm's are higher than that, internal gets the nod.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
Old 12-02-2006, 11:34 AM
Cobra Make, Engine: 66,clasic 351w,what a dog,needs boss 42
Send a message via AIM to wboss429 Send a message via Yahoo to wboss429
Use A 1028 Fel Pro You Should Be Fine,no Copper,
c9ae-zx
