01-16-2007, 10:40 AM
NC
Cobra Make, Engine: SPF #2101 Diamond Ed.; 460
Looking for Comments on 460 Build and Components
I recently purchased a Superformance with the following engine build. I am looking for info/comments/input as to what is good or bad in this particular build. Thanks in advance.
Joe
460 Cobra Jet Bracket Race SVO
10.5:1 Compression ratio
Edelbrock Performer 460 intake manifold w/Holley 750 CFM
SVO Cobra Jet aluminum heads with SVO valve train M-6049-B429
Polished valves - Intake diameter 2.25" & exhaust diameter 1.76"
SVO high performance hydraulic flat tappet camshaft M-625-C460
Valve lift - .588" intake & .614" exhaust
Duration at .050" is 244 degrees intake & 254 exhaust
SVO 460 2-bolt main short block, oil and water pump, oil pan and harmonic balancer
March polished & clear coated under drive pulleys
MSD 6AL ignition and MAS Blaster 2 coil
Taylor Race 10mm spiral core wires
CSI-106 high torque starter
Aeromotive hi-performance electric fuel pump and pressure regulator
01-16-2007, 10:46 AM
QC
Cobra Make, Engine: Emerson cobra, 460 550HP
Did you buy all your parts yet? If not I may have some for you new, pistons, intake manifold, etc.
Joseph
The desire for imaginary benefits often involves the loss of present day blessings.
01-16-2007, 10:50 AM
NC
It is all already there and put together. I bought the car used and am just trying to get feedback on the build that was put together for this car. Thanks.
Joe
01-16-2007, 11:16 AM
Cobra Make, Engine: Shell Valley 460ci C6
From the part numbers you listed it sounds like you have a Ford crate engine. SVO is now Ford Racing... or someone built it from mostly Ford performance parts. Sounds to be approximately 500 hp...all good parts. All that matters is how does it go...and for how long.
01-16-2007, 02:49 PM
With those heads, along with the aggressive cam, you might want to think about a Torker II single plane intake. You should gain some high end power, without giving up much on the bottom....as if you would notice anyway.
6th generation Texan....
01-16-2007, 02:52 PM
Another thing.....the stock SPF exhaust may be choking off some power. You might investigate a larger ID less restrictive muffler.
01-16-2007, 04:08 PM
The Torker won't fit under the hood of the SPF.
You may benefit on the top end from a slightly larger carb.
You might want to check the rods and see if they are the stock Ford rods or aftermarket.
01-16-2007, 06:37 PM
Hi xlr8or,
I think ya got it backwards. Here are the manifold heights from the Edelbrock web site http://www.edelbrock.com/automotive/...#hoodclearance :
Edelbrock Performer 460 Manifold height: A-3.75", B-4.45" (same as stock)
Edelbrock Torker II 460 Manifold ht.: A-3.50", B-4.25"
As you can see, the Torker is 0.2" shorter in front and 0.25" shorter at the rear.
VOE here (voice of experience), as I stepped in this one when trying to fit my 460 under a decent sized air filter
01-17-2007, 06:48 AM
NC
Thanks everyone for the info. I was also wondering if the airfilter on the car might be too small. I ran the calculator on the performance unlimited site and it seems that it may be. It is the long, thin crinkle Cobra type. You can see pictures in my gallery. Thanks again.
Joe
01-17-2007, 08:48 AM
sc
Cobra Make, Engine: SPF #2457, Sunset Red/Titanium Stripes,460FR, SCJA, TKO 600
The Ford Racing oval filter is on my 460. Check my photos.
"The Cobra is a 40 year old design that moves people like no other".
01-17-2007, 08:55 AM
NC
Yep. I think that is the one I need to switch to. The one I have is longer but much thinner.
Joe
01-17-2007, 09:00 AM
sc
Joe, my intake is the Edelbrock RPM Performer - dual plane.
01-20-2007, 09:06 PM
NA
Cobra Make, Engine: Superformance (SPF2265) 482cu, Tremac TKO 600R
Replace your factory rocker bolts with longer threads. The factory rocker bolt has about 12mm of thread and sooner or later tends to snap the rocker post clean off the SCJ Kaase heads. Also add rocker girdles to tighten everything up.
The single plane inlet manifold will fit under the hood.
Have a balance tube installed between your side pipes, this will resolve the HP drop due to the SPF factory pipes.
Nice colour car!
