Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 06-19-2007, 01:11 PM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Default 1969 460
I am having a 1969 460 built. I chose that year block because in NY the emissions are based on the year of the motor. PVC is all that is required in 69.
Question: Since I changed from a 1973 block to the 69 block I was curious if there was a difference. Is one better than the other?
Thanks.
Old 07-04-2007, 04:46 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
If you can get a 429 SCJ 4-bolt main block, that would be great. Other than that, they're all the same
Old 07-30-2007, 10:35 AM
The early blocks have a little shorter deck hieght than the later blocks, so if you zero decked with the 73 and you're switching over the rotating assy, the pistons might end up above deck. If they are, just have the machine shop shave the pistons. .010-.020 off the top won't hurt a thing.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
