Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 08-22-2007, 10:40 AM
Cobra Make, Engine: Superformance #046 Dart 427w
Default Blue Thunder 2x4 intake
I will be putting a Blue Thunder 2x4 intake on my 64 T-bolt, with a built 460. I am thinking of using a pair of Holley 600cfm carbs. I am not sure if this is a good choice of carbs.
Old 08-22-2007, 11:09 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
The 600cfm holleys work good for me.
Old 08-22-2007, 12:11 PM
Once you experiance a demon you will never run anything else.
Old 08-22-2007, 03:01 PM
lineslinger's Avatar
A set of Holley 750's on a BT dual quad intake.
Old 09-05-2007, 06:06 AM
A pair of 600s will work just fine. Be sure to check for a good seal around the mounting to prevent vacuum leaks
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
