Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-04-2009, 10:14 AM
Question What to do with a 1970 429 for rebuild?
Rebuilding an N code 429 Thunderjet engine for high performance street,with a pump gas,93 octane,friendly compression with the iron 75 cc or possibly the Edelbrock RPM Performer heads. Anyone have any piston combos that will work for this? 9-9.5 compression with the stock 75 cc iron heads? Or 10-10.5 compression with the aluminum RPM heads?
Old 04-07-2009, 05:48 PM
When using 75cc heads:
9.25:1 will require a -20cc dish
10.25:1 will require a -10cc dish
Flat tops will give you approx 10.7:1 if left in the hole a bit, which can work with alum heads and pump gas.
There is unfortunately a very limited selection of off-the-shelf 429 pistons available if using a stock rod.
Stock cast replacements like the Silvolite 1161's have a -12cc dish
KB offers hyper flat tops
Speed Pro offers forged flat tops
Other than that, you'll need a custom
You can use 460 pistons with the 429 crank and aftermarket cadillac rods if you're willing to do a little work on the rod bushings.
You can also use a 460 crank, the rods you have and 460 pistons.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
Old 04-07-2009, 07:38 PM
I know it'll stroke to 501. Use Edelbrock or Cobra-jet heads with a 10.5:1 compression and get over 600 HP.
" It ain't no big deal"
Old 04-07-2009, 08:20 PM
lovehamr's Avatar
Stolen Avitar
He he he!
http://www.jonkaaseracingengines.com...bbf-heads.html
Cobrajet, smobrajet!
Hey, you asked! Steve
Old 04-07-2009, 09:54 PM
Originally Posted by lovehamr View Post
He he he!
my thoughts exactly.
