Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 08-08-2009, 03:15 PM
PAINTER's Avatar
Cobra Make, Engine: West Coast
Default Motor loses fuel pressure
Motor loses fuel pressure.
I installed a new alum fuel tank and started having a fuel problem.
Driving at a normal speed and it will just die.I change the electric fuel pump and it didn't fix the problem.The pump runs at 6.5 lbs to a eddlebrock 750 carb.
It does'nt happen very often but it could happen at the wrong time.If i pull over it will usually start up.It's not a heat issue because it has happened on cool days without the engine up to temp.I cleaned all the lines and filters and found no problems.The engine is a 460 crate 4 years old.The first three years did't have any fuel issues.I changed the tank because of fuel smell in the trunk with the plastic fuel cell.The tank is not vented but I tried driving with the gas cap open a crack and the problem didn't go away.The new tank was very clean wnen installed.
painter
Old 08-08-2009, 04:01 PM
My guess was the vent........but you might check to see if there is a filter on the end of the pickup and maybe it has something on it or it has a kink in it ......or your ground on your pump is bad.......good luck.
Old 08-08-2009, 09:05 PM
Gaz64's Avatar
Driving at normal speed and it just dies?
Does the car make normal WOT power?
Do you run a fuel pressure gauge within drivers view?
