Thread: Transmissions
Old 01-26-2004, 11:17 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
You might want to take a look at the rear end ratio as it will apply to the Tremec and make sure that the relatively low 1st gear ratio will work for you and whatever tires you're running.
There are a number of gear ratio calculators that will give you the numbers.
DonC
