Old 02-24-2004, 11:18 AM
SFfiredog SFfiredog is offline
Default Re: off the thread, but, heat soak?
Originally posted by Pete Munroe
FD,
This is off the thread of the PCV, but woh does the system handle heat?
(Very nice workmanship.)
Is there any problem with vapor lock on a hot day?
I do not know how high the boiling point is raised with 30 to 40 lbs of fuel pressure, but it seems like there would be a problem restarting on a hot day, hot engine.
Pete
Hi Pete,
The lines under the intake are vacuum only, no fuel runs through them. EFI uses 42 psi and had a return line system so that the fuel is never on the engine long enough to get too hot.
HTH,
Mike
They bend 'em, we mend 'em.
