Old 02-24-2004, 12:44 PM
MAXVELO MAXVELO is offline
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
Send a message via AIM to MAXVELO
Default 1/4 MILE TIMES?
When the car was owned by Weld Motorsports He (Carl Robinson) said it did just under 9 sec. with a set of slicks. As for the "air cleaner component" im assuming you mean the Carb Bonnet/ Blow thru etc. Because the air cleaner is under the car between the engine and tranny.It is a procharger unit that I had the fins machined off and the wrinkle finish sanded and then polished the unit. I am accually going to get rid of it and change to the Extreme Velocity unit at superiorairflow.com. with all the $$ I spent on this unit I coulda had three of the Extreme Velocity units! I have my red line set at 6200. I have a Nasty power band between 2800-6200. I dont think its starving for air since I have a constant 7-9 PSI of boost thru the band.
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
