Old 03-27-2004, 08:42 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
ERA649:
Check Finishline, they have the side pipe guards.
Cobra de capell:
I'll be using a Secret Audio receiver which has a remote control head about 6.5" long by 2" high by .75 inches deep which is all you see up front. The base unit is mounted in the trunk and out of the way. Speakers in the outboard side of the foot boxes and behind the seats. Amplifier and CD Changer also mounted in the trunk.
The unit is controlled with an RF remote similar to your TV or with buttons on the control head.
Don't know yet if I'll use a "thumper" (sub woofer). Depends on how it sounds when completely hooked up. If I do go with the thumper I'll be looking for a free-air unit and place it in the rear bulkhead of the driver's compartment between the seats. The free-air unit uses the trunk as it's enclosure so it doesn't need a sepreate one.
DonC
