Thread: T56
Old 04-04-2004, 03:39 PM
Leeroy's Avatar
Leeroy Leeroy is offline
Know the feeling when you start to cut that shaft and you only hope you have done the right thing. What shift did you use Phil. I reused the original linkages after much machining etc. and it seems very direct and easy to shift in static mode, so I hope its ok when up and going. Fitting the lockout soleniod was pretty easy but you need to be able to tap thread for the solenoid to fit. I bought the tap so if any of you guys want to use I can courier to you as tap was around $50 and couriers are cheap.
Leeroy
