Old 04-06-2004, 10:56 AM
NeedAntiVenom NeedAntiVenom is offline
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
Rick,
Two tubes, 8 Oz. total, of GM additive, the diff will take about 2 quarts of lube. I had some chatter problems - fixed with two tubes of antislip and Moroso climbing gear lube as ERA recommended.
The PowrLok is a little different than most LSDs because it has ramped cross shafts that compress the clutch pack as more power is applied.
Hope this helps.
