Old 04-06-2004, 03:17 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
I would follow the ERA advice. They have alot of factual data and they advise the use of Moroso Climbing Gear Oil which is an SAE 90 weight oil (you can get this from Summit) combined with 8 Oz. of Amalie Limited Slip Differential Additive or 2 tubes of GM Limited SLip Additive (GM Part # 1052358).
The additives make the lube slippery and stop "ratcheting" or sticking and clunking when you go around a sharp corner.
If you cannot find the Moroso CGO, then use an 80W-90 GL5 gear oil with one of the two Limited Slip Additives.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
