Old 04-19-2004, 05:57 AM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
The button on the turn signal lever is your high beam switch. I used a Painless 12 circuit wire set. It had a GM plug that hooked up to the wires coming out of the column with the GM connector on it. The wire colors were the same which made it easy to hook up.
