Old 04-20-2004, 05:29 PM
starwolf56's Avatar
starwolf56 starwolf56 is offline
Cobra Make, Engine: Classic Roadster,351w 405HP
OK,the main column connector did connect to the CR harness.
Art, did you use the dimmer relay from Ididit? If so, where did you connect the red,blue and the brown wires coming out of the relay?
Does anyone have pictures of the column mounting? What are you guys using?
DV: I think that there is a extra number for your fax. Could you list the correct one.
Thanks for the help guys!
