Old 04-21-2004, 09:20 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The headlight dimmer box wires into the plug that would normally go to the GM dimmer. It has wires #141, 143, and 145. Check the dimmer box wire functions and run them into the CR wires using spade connectors. The CR wires are, #141 is power to the dimmer box, #143 is for the high beams, #145 is for the low beams.
Don
