Old 04-22-2004, 07:02 PM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Just be careful when you bolt in the steering column. I caught one of the wires between it and the mount I made to hold in column and cut the wire that went to turn signals and brake lights. I kept blowing fuses . Finally pulled down the column and found wire that was grounding out. Then the emergency flashers wouldn't work, so I got out the test light and immediately stabbed my finger ( I hate when that happens) and finally discovered I forgot to replace the fuse for emergency flashers. Duh!!! Thats why I always check the fuses first now!!
