Old 04-26-2004, 09:41 AM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
One other thing you have in the Ford over the Chevy is the lifter bore size. Ford .875" or GM .842", and since a flat tappet camshaft's design is based on lifter diameter. The larger the lifter diameter the faster the rate-of-lift that can be designed into the cam lobe. This doesn't really apply to roller cams though. On a side note, the Mopar bore is .904".
Brent Dolphin
