Old 05-03-2004, 10:36 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default They are very quiet for sidepipes (at idle)
But when you put your foot into them they emit a nice throaty grumble.
Be aware that there is a tab at each end of the baffle, both of which need to be drilled for and mounted. I did only the easy to drill front tab at first and received a nice rattle at idle for my laziness. I then removed them and took the time to mark and drill the rear hole. An angle head on a Dremel, with a shortened pilot bit helps here.. then you can drill the hole to full size from the outside after verifying the accurate center of your pilot hole.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
