Old 06-02-2004, 03:11 PM
DAVID GAGNARD's Avatar
Thanks guys for the replys.......
Spoke with the people at Griffin Radiators,they make pretty much any radiator size and configuration you want,they also can put either an engine oil cooler or auto trans oil cooler in one tank.... The AN fitting are a different size for each.....They do make and have a number of radiators in NASCAR/Busch series and while most use the air/oil cooler they do have some teams using the engine oil cooler in the radiator....
My two concerns were the ease of installation and cost....Oil cooler in the radiator is a lot easier to plumb and a very simple deal and actual cost is less than a radiator and seperate air/oil cooler,I'm going to run a Griffin radiator either way I go....
Still undeceided which way to go and have plenty of time before I get to that point....Thanks for the replys and if anyone else has anything to add,please do......
David
DAVID GAGNARD
