Old 06-11-2004, 07:17 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
PULL THE UPPER AND LOWER PLENUMS AND EVERYTHING THAT IS ATTACHED TO THEM. COMPUTER, FUEL INJECTOR WIRING HARNESS ECT. INSTALL A INTAKE AND 600 OR 650 CFM CARB. A 302 ENGNE NEED 541 CFM AT 6500 RPM. DON'T OVER CARBURETOR YOUR MOTOR! REPLACE THE FUEL LINE AND FUEL PUMP. EFI FUEL PUMPS ARE RATED AT 38 TO 40 LBS PRESSURE. MOST ARE IN THE FUEL TANK. CARB PUMPS ABOUT 4 TO 7 LBS. THEY ARE MOUNTED CLOSE TO THE FUEL CELL. OR YOU CAN USE A MECHANICAL PUMP. USE A 3/8" STEEL FUEL LINE. MAYBE A NEW THROTTLE CABLE AND OTHER SMALL PARTS.
SELL ALL YOUR FUEL INJECTION STUFF ON THE ffcobra.com SITE.
