Thread: Engine mounts
Old 07-10-2004, 08:55 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Hi David,
I'm using a pair of Corvette mounting ears for my motor and I got them when I bought my motor from Eagle.
You will probably find that the left and right Holden mounts are different. I seem to remember one of them is the same dimensions as the Corvette mounts and you need to run 2 left hand ones or 2 right hand mounts or something like that. Ian should be able to tell you.
Check and see if your mounts will swap left to right and check if they are the same size.
Is there a gen 3 Commodore in the work shop you can look at to compare?
Mike Murphy
Melbourne Australia
