Old 07-10-2004, 03:56 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
When you install the wire at the spinner, make the connection in the back of the spinner and cut the leader long enough to curl it behind the spinner with a needle noce plier into a curly-que. This prevents you from tearing up your hand up when washing the wheels, and it looks better too.
As to the spare, I hav a can of fix-a-flat in the trunk, as I have no jack and if you have removed your spinner you can imagine doing it on the side of the road. I have considered purchasinf a tire plug kit and a can of air or a small 12v compressor. But then I think, that what credit cards are for. Also, the Fix-a-flat would trash the tire I'm told. Two different size tires...the list goes on.......
