Thread: Engine mounts
Old 07-11-2004, 11:26 PM
Leeroy's Avatar
Leeroy Leeroy is offline
I agree with Phil I have used Don on most bright works and they are great. I had my swaybar made locally by giving a pvc rod replica of what I wanted, just got all the mounts etc. and bolted rod in place and with a heat gun bent it into the correct postion to mount to linkage points on front end.worked a treat and ended up costing around $200 all up. Do you have a spring works or heat treater in town who might do it. I also used the f/glass dash and had it painted the same as body and it looks great. I also used corvett mounts and it dropped straight in, with the chassis cut away did that mean you could use holden mounts for altenator? I made one up as no cut away on mine.
Cheers Leeroy
