Old 07-14-2004, 09:08 PM
Northwood Cobra Northwood Cobra is offline
Cobra Make, Engine: B&B
Default Haywire harness problem
I've got a 7 fuse haywire harness and I have a full 12v draw on the negative side of the battery with the key off. If I pull out the hazzard fuse or the relay for the hazzard the draw is zero. The main power comes thru the fuse, into the relay and out of the fuse panel. With the fuse and relay in place there is no power coming out of the fuse panel after the relay . The test light only shows power in one of the prongs on the relay. I'm very confused.
Terry
