Old 07-15-2004, 10:24 AM
GeeDoubleYouSee GeeDoubleYouSee is offline
Cobra Make, Engine: Superformance 351W
Northwood:
This sounds like an Alternator problem, With the key in the off position disconnect the large red wire to the Alternator, if it sparks when you touch it to the post you removed it from, then its a diode burned out. change the Alt. everything should be fine after that.
GWC
