Old 08-03-2004, 04:57 PM
gsharapa's Avatar
gsharapa gsharapa is offline
If you check from under the car you will see where SPF has slit the fiberglass where you put the belt through and bolt it to the frame cross member behind the seat. The carpet has a small slit in it also but is hard to find. Frame is drilled already!
Gary
CAV GT40
