Old 08-16-2004, 06:57 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default power valve recamendations
You would think the Cam manufactures with all the information they have before they reccamend or make a cam ,would be able to reccamend a power valve range that would work.They surely know about how much vacume an engine will maintain with what cam and carb setup.When you ask for a reccamendation they ask every questio upto and incluning what you had for lunch.
Mine is a 427 Ford side oiler aluminum Dove Canadian Super Cobra Jet heads, 11.5 -1,Dove tunnel wedge 2x4 intake two 600 cfm Holley 4160 carbs.Comp Cams solid lifter cam 252° at .50" and .598"lift>That is close enough.Oh sealevel.
Mike H
