Old 08-19-2004, 07:26 AM
chuckbrandt's Avatar
chuckbrandt chuckbrandt is offline
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default That's close to mine, what are your cam specs?
Your build is very similar to mine, although your heads are undoubtedly better. I'm also standard bore because I started out with a 352 block.
What are your cam specs if I might ask? I went with a crane H-272-H hydraulic with might be a bit small for the cobra? The motor is going in a heavy old pickup when I'm done with it in the cobra so that was a consideration too.
Thanks, Chuck
Build website at www.chuckbrandt.com
