Old 10-16-2004, 08:19 AM
Specialk's Avatar
Specialk Specialk is offline
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
Dominik;
I am not familiar with some of the terms you are using, but :
the horizontal bracket supports the trunk insert, but only if lifted up a bit to clear the rear shock mount brackets.
The shock mounts are slightly above this tube. On the S/C cars, the triangle shaped trunk aluminum piece that sits on top of this horizontal tube has a step on it where it meets the the tube. That raises the aluminum above the rear shock mounts. Obviously if it were sat flat on the tube with no step it would run right into the mount. Kirkham redesigned the shock mounts so they sit just low enough to clear. I am sure the glass fiber trunck tray is built with these same provisions
You can see this step in this photo of CSX3020:
kris kincaid
