Old 10-17-2004, 03:19 PM
Terry Give me a phone number. I can walk you through it to find the problem. I have the wiring diagram from 330 on up. For the horn check fuse 2 on the fire wall and see if you have power to both sides of the fuse. Then check the horn relay. it has 3 wires going to it. Green, Violet, and Pink. Ground the pink wire to the chassic and the horn should work. if not listen for the relay to click. Check the fuse holder under the dash and see if both are OK 2 amp fuses. I will have to talk you through the rest. Rick Lake
