Old 10-19-2004, 02:49 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If you run the batt and starter cables reversed at the solenoid, the starter will work fine, but the hot lead to the + on the coil will always be hot, always even with the key off, not just during cranking, as intended.
