Old 10-19-2004, 08:50 PM
maxrpm maxrpm is offline
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
Originally posted by SVMCOBRA
Hey Outlaw, I had a slight binding problem with mine. Check the brass pillow block that supports your column close to the steering rack. I had to add a shim to the top bolt ( between the block and frame) and my problem cleared up.
^^Here's the problem right here.^^ Shoot some WD-40 on it and you'll see a big difference instantly. Then do like SVM says.
"If you're not racin' it, you're wastin' it!"-Me
