Old 10-21-2004, 05:15 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Check the FRONT signal lamps
I have a gremlin with #404 rear brake light not working, but parking lights did work. Found out that if a front signal lamp is bad it will keep the rear ones from working as well. Found that the right front signal lamp was loose and when I re-seated it everything started working again. There's a note on this in some of the ERA wiring info, but I had to dig a while to realize this might be the issue.
