Old 11-03-2004, 08:21 PM
larryg larryg is offline
Thanks for the advice Sizzler. Are you talking about the front cover behind the crank pulley? If so, that is what I am missing as I have not removed any of that. There were two recessed bolts at the base of the front on either side of the crank pulley, those are out but I did not remove the crank pulley or anything behind it.
BTW, it is a Dove motor and I talked with Jim the other day about it. Basically he said he hasn't pulled the pan with the motor in the chassis but gave me a couple of things to try such as the fittings on the passenger side.
Thanks again,
(yeah, on Ogden)
EDIT: back in the shop this morning...this motor does not have a big hose coming out of the front cover on the driver's side unless you are talking about the hose coming off the water pump. There are oil lines coming out of the driver's side of the block.
