Old 11-16-2004, 05:08 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
What is the lift and duration of the cam. I'm not familar with the X cam. I run a Crane. The lift on a stock shortblock 87-83 can go as high as .544 but if it has a lot of duration its going to hit a piston. You should always check. If its high lift and high duration I say you'll need to notch pistons or go aftermarket.
