Old 11-16-2004, 06:28 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
It really doesn't matter what dip stick you use as a reference as long as it stays the same. You really might consider a Lokar or even a properly secured OEM unit. www.lokar.com
As far as oil "use"... If your FE has a leak oil use is relative. How much are you leaving on the ground? Another big area of "usage" is a leaky in take manifold. Are you confident your intake isn't sucking oil into the runners? You really might consider pulling it before considering how much oil you are "using".
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
